rear end
kbflip02
Car: 1994 Infiniti J30
2006 Infiniti G35x
what gears are in the stock rear end of the J?
brandonjustice93J30
Car: 1993 Infiniti J30
3.917- j30
zerothread/22769
kbflip02
2006 Infiniti G35x
is the transmission the same as a 300zx NA???
Q45tech
Yes same RE4R01A in both, however 300zxTT has the Q45 RE4R03A.
kbflip02
2006 Infiniti G35x
Q45tech wrote:Yes same RE4R01A in both, however 300zxTT has the Q45 RE4R03A.
so what should be done in order to service the rear end???i heard someting about changing the diff fluid...but is that all?
gr8scott72
Car: 1994 Infiniti J30t
kbflip02 wrote:so what should be done in order to service the rear end???i heard someting about changing the diff fluid...but is that all?
Drain and fill. That's it.
Plug at bottom to drain. Plug at top (Driver's side IIRC) to fill.
Hint: take the fill plug off first so you don't find out AFTER you drained it that you can't get the fill plug off. It's kind of hard to turn the car upside down to refill the diff.
