4x4parts sells polyurethane bushing kits. I don't know how much you paid for yours, so I'm not sure if 4x4parts' pricing is crazy or not.Datsundimeguy wrote:Hey guys. I just replaced both the upper and lower trailing arm bushings with urethane ones in the rear, because I had the same problem. I was a tech. for Nissan and we saw this regularly. I had a really hard time finding urethane bushings and I didn't want to replace them with the stock/aftermarket rubber ones. So I found some from Australia. I inquired about ordering direct, but shipping was over $100. I found a local distributor and ordered two of the rear sets and one of the front control arms. No shipping charges...I have a set of the T/C (radius) Rod bushings on order as well. Those rear bushings are such a huge difference! Better than new! I'm talking Antarctica to Bahamas different... here is the link to Whiteline Products...They may not have them in stock as they had to produce mine and it took just about 6 weeks. It took me a few hours at home (but I have a hydraulic press) and I'm glad I searched for the much improved urethane over rubber.
http://whiteline.com.au/do_segue4.php?m ... =5%2F95-03
Good luck.
