If you really want to save some money, try rotating your tires and see if it makes any difference at all.brokeAs240sx wrote: Have you tried rotating tires and see if anything changes?
Obviously, if you felt the rear shaking... once you rotate to the front, the steering wheel should theoretically shake if the tires are not balanced. And your rear "should" feel more stable if your front ones were more balanced, per say.
