Rear end rebuild
RagingPanda
Car: 78' 280Z
I have a Kaaz 2way and plan on putting it in very soon. While it's out I also want to rebuild the rear end by replacing the Pinion bearings, seals, and crush sleeve. THe problem is that I don't know which part exactly to order from Nissan and it's nonrefundable so i would like to make sure 100% before throwing my money out. I've attached 2 pics. The first is a pic of the rear end w/o the differential. The 2nd is with the differential. Can someone plz help me indentify the parts I need. I need the gasket of course(38320 ). I cannot find the crush sleeve because i think it's in the flange(38210). One of the pinion bearing is (38140) and the seal is (38189). There should be 1 more pinion breaing and i'm thinking it's (38120). Plz help me find the right parts i need to rebuild the rear. I don't want to order the wrong thing and can't return it. Thanks a lot
RagingPanda
Car: 78' 280Z
WTH...the image is not showing up...so here's the link. Plz click on them. thanks a lot again.http://www.geocities.com/dsaiyanz/wodif ... /wdiff.jpg
BoyWonder
Car: '93 Nissan 240SX S13 Convertible (reclaimed... wootles)
Pictures are definately unavailable :(
RagingPanda
Car: 78' 280Z
I order the Kaaz from Phase2motortrend. It said that the kit comes with gasket and seals for installation. So does that mean I don't need to order a gasket fromNissan? As for the seals, I still have to order them because it's the different seal. Am I correct or wrong? thanks
RagingPanda
Car: 78' 280Z
I don't get it...when i clicked on the link the page is unavailable but when i type it out manually on the url bar it works....wtF?!! It's the same stupid URL...sorry for the trouble but can guys type it out or watever manually cuz i'm sure the links are correct and the pics are there.
mav1178
http://www.overboost.com/story.asp?id=1138
Or search on Freshalloy for differential install by me or Asad or several others. There's no real need to replace anything in the rear end other than gaskets and seals.
-alex
RagingPanda
Car: 78' 280Z
I know that is not require to build the rear but i want to make it permanent and once and for all u know since it's out. If it's so much trouble then i probably won't do it.
