rear end ratios
Mayhem_J30
Car: Ummm...My Car
I've asked some generic questions in the 240 section but the experience is limited with this subject.
I found some 4.364 rear gears that nissan motorsports offer for the 89-94 240sx so I assume they would fit the J's rear end and replace the current 3.92. Please comment on the other options as well: 4.083 and 4.636. Personally I think the 4.364 will be just right and I'm not worried about gas mileage since the J30 is no longer my daily car. This looks like about a 11.3% change so I would assume mpg to be decreased by a similar amount just as rpm to increase by a similar amount.
-Also they offer new speedo's to compensate for the different gearing. Which # of teeth is necessary to keep my speedo accurate with the new gear? Available is 17t-22t.
-Last thing, I am familiar with replacing driveshafts on other vehicles so that might give me some advantage, but will this job exceed the skill level of most DIY'ers?
Mayhem - Do a search for "4.08" - Dennis had some good insight on the subject.
That's SO NOT a DIY. That's why I said in the other thread that you'd be better off doing a bolt-in swap, unless you're hooked up with someone from a driveline shop (except that the 4.08 would do you no good). Call around and see what a ring/pinion swap would cost... Pretty pricey job.
Rearends are super-difficult to set up properly, even in an old domestic car with less specific tolerances.
Mayhem_J30
Car: Ummm...My Car
hmmm...which part is the hard part, pulling the diff out to work on or working on the gear swap?
Q45tech
The gears must mesh exactly as the load varies with acceleration cruise and deceleration.......to get 150k life --- a bad job can wear out the gear contact points in 1,000-5,000 miles not to mention the noise. A bad job lets the gear wobble and wear and explode.
11.3% more rear gear multiplied torque [cuberoot 2.2%] would be the approximate acceleration gain in gears for the quarter.
Lot of work for 0.2-0.3 seconds.
What if you tried to couple a 90-93Q transmission with its 5% lower 1st and 2nd gears........when you think about it this is what they did in the 90-95 turbo 300zx AT vs the normally aspirated 300zx.The ideal 1st gear x diff would be around 13 to 1 vs your current 10.8 or so [the Q is 9.85 to 1]. The new BMW 745 has a 14.1 to1 1st gear and shifts @ 37,66,102.
The 4.63 would be ideal [to maximize acceleration] for the Q/J [but who could stand the 30% lower gas mileage] and 60,000 mile engine life reduction from increased cruise rpm.
With any gear change you must evaluate the effect on the 50-70 mph pass as you can get yourself into problems if a slow shift occurs in the middle of a pass facing a semi. No gear willl make up for the [up to 1 second] time lost during the shift!
This is what's killing many of the new 5-6 speed AT they are optimized for zero to 60 and a near 100 mph quarter but must shift 62-72 mph vs the old 4 speeds which stay in same 2nd gear from 50 to [80-85-90-95].............everything is a trade off.
Mayhem_J30
Car: Ummm...My Car
I would much rather go a route where 1st through 3rd could be lowered and 4th stay the same for cruising purposes. But modifying a transmission rather then a diff sounds a lot more difficult although it also sounds like it would yield better results especially in the long run.
Q45tech
All the 90-01 AT have the same 1.000 3rd and 0.694 4th gear......the newer AT 5 speeds have a 0.8 gear for 5th so all the new diffs 2002 [G/Z/M/Q] are less than 3.4 to 1. [ 2.8 to 3.331].The new 6 speed manual uses the same as old Q 3.538 to 1.
There is no easy solution.
diamondj30
Car: Not to low , not to high , just right .
hey criss,when i did mine it was 1500.00 to put the 436 gears.glad i did.10 over on the speedo.the geasrs are about 500.gotta go.
Mayhem_J30
Car: Ummm...My Car
diamond gave me the idea to begin with but since he's been busy lately i haven't been able to ask him all of these questions. hang around more brother
diamondj30
hey criss,by your sig,it looks like you have a badass j30.
