mikesudds »
https://forums.nicoclub.com/mikesudds-u8618.html
Fri Mar 11, 2005 2:49 am
first off i did search for this, and i found nothing.
i have a 92 nissan 240sx.it has tein s type lowering springs.i'm running 245 45 16 tires on 8 inch wide wheels in the rear.when i hit a small bump in the road, i get very aggressive rear end "float" it's kind of like when the tires break loose when you shift a gear. how the back end of the car shifts to the right or left.it does this even over very small bumps.i hope that makes sense.i am running stock struts in the rear, and the car has stock subframe bushings.is that my problem? it's almost to the point of scary when i drive the car now.thanks for any input guys.
