REAR END on 03 m45???
saeedakobiakov
Car: 03 M45
Hello,Can anybody explain to me how the rear end works on 03 m45 without lsd?why some times my car leaves one tire mark and some times double?
Thanks,Caug
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
It's an open rear end with TCS, so it only reduces power to the spinning wheel rather than transferring the power to the wheel with traction as an LSD does.
When you have good and equal traction, no TCS intervention and double stripes.
saeedakobiakov
Car: 03 M45
i am still confused.what is tcs?i always switch off traction control.i was lunching the car straight without any debris on the road.what would it do if i shot off completly ?one mark or two?Thanks,'caug
qship96
Car: 1996 Infiniti Q45
Put it in neutral, rev it up to about 6,000 RPM and drop it into drive with accelerator floored and report back to us.
saeedakobiakov
Car: 03 M45
my friend did it 12years ago in 4.0 grand cherokee. the drive shaft dropped.it was fun,but thanks for advice though.
jamestgk
Car: 2003 M45
turn off the TCS (traction control system) pit into first gear and with gentle power braking you should get two marks. or just punch it and you should get two. i rarely get one. Have you serviced your rearend lately? drain and fill with synthetic
saeedakobiakov
Car: 03 M45
i got full synthetic all around.i did bunch of lunches, looks like two marks most of the time, but still cant figure out why i see one some time. i think when just flooring it without power braking it will leave one mark and with any kind of power braking you will see two.i going to try both.thanks,Caug
