Rogue One wrote:Wow, definitely leads credence to ImSrickens rants er commentary on Nissan using inferior parts to save weight in order to boost fuel economy. I've got a few squeaks and rattles, but nothing like what you've described. As for the rear door locks, can you record the noise and post it?
When are squeals signaling a problem?
Sometimes brake squeals are an indication that maintenance is required. Some common conditions that cause brake noise are:
* Heat cracked or worn "un-true" rotors
* Rough finish on resurfaced rotors
* Loose fitting brake pads in the caliper
* Lack of silicone compound on back of brake pad
* Missing springs or anti-rattle clips that should be on the caliper or pad
* Improper tightening sequence of lug nuts or caliper hardware
Try cleaning the caliper slides and the pad abutment points and lube them with a synthetic or ceramic-based caliper lubricant. Same goes for the clips. The shims should also be lubricated with a synthetic caliper grease.
Thanks man, if it keeps up I may try that... Or when I bring the car in to Nissan for the door locks, I may just tell them to do it...
I'll get a vid of the door lock sound today
