evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Nov 15, 2007 6:54 am
no not hard at all, the trans mount just requires you support the trans while you pull the crossmember and replace the mount, the pinior mount doesn't really require you support the pinion but if you put jack stands under the inside tube on the laca's it holds them in place while you pull the crossmember, the bolts that go through the front of the diff can be a pita but not really a big deal, honestly it's easier than dealing wth a u-joint as the u-jointts are not servicable and would have to be replaced at a driveshaft shop
