PoorManQ45 wrote:I've had a few close encounters with cars with no brake lights. I bet it would be impossible to prove that the lights weren't working after the accident though
Not necessarily. While the article I'm posting deals more with headlights, to some extent, it could be applied to any light bulb.
http://www.waltersforensic.com/articles ... 1-no18.htm
MinisterofDOOM wrote:I'm still not even sold on the necessity of ABS. Anything more controlling than that is definitely not okay in my book. Computers can only judge by the data they are provided. They can't know outside details. They can't judge the "lesser evil" of a collision. They can't tell how YOU the driver might try to react, how their own reaction might interfere with that, or how--Heaven forbid!!!!--the driver might ACTUALLY KNOW WHAT THE s*** HE'S DOING AND BE FINE WITHOUT ELECTRONIC INTERFERENCE!
Is ABS necessary? Nope. No safety system is necessary. But it usually helps. ABS, in most situations stops in less distance and allows one to have a great deal of control. Ultimately, ABS allows each tire to "threshold brake" individually and actively with changing conditions at each tire. No human can replicate that without 4 separate pedals. And even if one did, it would be unlikely that they could manage to brake each wheel at the threshold consistently. In a comparison between the Honda CBR 600 and its ABS counterpart, skilled riders (including racers) could manage to match the stopping distances of the ABS model (mind you its a 2 channel brake system) but struggled to do it repeatedly. In an accident avoidance situation, you only have one chance.
MinisterofDOOM wrote:Scenario:
Coming around a blind corner, you encounter a stopped car in your lane. Reason doesn't matter*. Behind you is a semi, also unprepared to stop. IF you stop (or the car stops FOR YOU ARRGHGHGHGHG) you're going to be a dead sandwich. But if you SWERVE...you might just make it. At the very least you'll turn a horrible triple-pileup into a clipped corner. Oh, but guess what...the car has assumed it knows better than you and you're already stopping. Congrats, you're dead. Too bad.
It doesn't sound like you lose the ability to steer. And I can't imagine its not adaptive in the sense that when it no longer senses the danger, it reduces or eliminates its involvement.
MinisterofDOOM wrote:Sorry. It doesn't matter how bad a driver a person is, they will still ALWAYS have a better set of data by which to make reaction decisions than any collision prevention system.
Not always. Most people get into accidents because they didn't put attention where it needed to be. And if a person happens to be lacking the attention directly in front of him at the the wrong time, he has less data than is relevant at that moment.
MinisterofDOOM wrote:Keep this s*** OUTTA MY CARS. I've gotten by for years without electronic nannies and I intend to keep on that way. When s*** goes wrong I have MYSELF and ONLY MYSELF to contend with. I'm not fighting TCS trying to belatedly contradict me. I'm not fighting ABS thinking it knows how to brake better than I do. I'm not fighting radar bullsh*t thinking it knows how to avoid a crash better than me. When I don't have to think/worry/fight with that garbage, MY OWN reaction ability is improved.
So has most of the population. Most people have never activated the ABS system in their cars. But its good to have when they do need it.
MinisterofDOOM wrote:I feel the same way about this crap as I do about Infiniti's "lane departure prevention."
The more we take responsibility for MAINTAINING control of the car away from the driver, the worse off we will all be. In 25 years when no one knows how to drive anymore because the car does it all for you based on assumptions from narrow datasets, the roads are going to be one scary f**king place.
I don't think anyone is trying to remove control from the driver; as if a driver is going to simply let go of the wheel and let the car drive for him. The only lane departure system I've experienced is on my sister's FX35. It doesn't intervene or anything, but simply beeps. Annoys the hell out of me since it goes off a lot when I drive (I change lanes more often than an average person), but my sister doesn't seem to find issue with it.
MinisterofDOOM wrote:And I haven't even gotten into the INCREASED potential for things that can go wrong when you start handing over complete braking control to the car.
On the other hand, if a person, for whatever reason, is not paying attention to what's in front of him, and does nothing, and the car stopped itself, wouldn't you say that decreased the potential? I handled more than 10,000 accident investigations. Most stem from a moment of inattentiveness. We, as people, are not infallible. Aids that can assist us in avoiding accidents should not be unwelcome. Could there be some bad side effects? Sure. Seatbelts aren't 100% perfect. But if they save vastly more lives then they take away, is that not a good thing?
MinisterofDOOM wrote:I also dislike the idea of anything that "pre-loads" the brakes. That just means you now have no idea how much brake pressure is necessary to stop. Unless your brakes are utterly useless, you don't need "pre-loaded" brakes, you just need to press the effing pedal harder! But when the car changes brake response at panic moments, your ability to respond is--YET AGAIN--impaired.
I have no idea how such a system works, but I'd speculate the "pre-load" is nothing more than cutting off the port between the master cylinder and the reservior so that there is quicker response from the pedal (when the port is exposed pressure build-up in the system is progressive until the port is closed). It doesn't change the amount of pressure required on the brakes. And in such a case where an emergency is imminent one will always want better brake response. Most people don't brake hard enough initially when they see a hazard. The natural reaction to any kind of braking is usually to seek feedback (that is brake progressively harder until one achieves the amount of deceleration they desire). The other response is usually panic in which case a person slams on the brake and would lock-up the tires if they do not have ABS. The concept of brake assist in various cars was implemented because of this fact. All these sytems are coupled with ABS though so it really shouldn't get out of hand.
MinisterofDOOM wrote:*I had this happen to me a few months ago. Early morning, very little traffic, all of it clumped together. Coming down a curving overpass, I find a woman in a Corolla STOPPED in the middle lane of a 65mph highway because there is an accident ON THE SHOULDER--no one in front of her. I moved around her, but she very nearly caused a multi-car accident with her stupid.
Just imagine if a less attentive driver was behind her. Perhaps it would have been an accident. And perhaps a system like this might help avoid some of these types of accidents.
All that said, I don't fully disagree with you. I'll reserve judgement on this system until I see how well it was implemented. And for me, I'd probably prefer not to have it if it interferes with how I prefer to drive. I usually have to turn of TCS and VDC systems in most cars I drive. But I don't resent such systems fully as I know that there are people who might need such a system and that most drivers wouldn't regularly be affected by such systems) But hell, if it keeps me from getting rear ended by some moron, I'm all for it (in concept anyways). We'll have to wait and see how well it actually performs.
