DrewQ45 wrote:How's everyone keeping? Been a while since I posted in the Q forum. I see big things are happening all over. You guys never cease to amaze me. Turbos and all....
My rear end has developed a whine for a few months now...it has grown progressively louder as the miles rack up. At 60mph, it sounds like a muted air raid siren emitting one long tone and is loudest when I remove my foot from the gas.
Today I ran the car on jackstands and my ears were ringing when I crawled out from under it. I pulled the fill plug to make sure it has enough fluid and it does... I changed to full syn about a year or two ago. Guess it was too little too late with 227K on the clock and all. I'm gonna pick up one from the JY soon but wondering which year is best. I'm not sure if 94 plus will have a different gear ratio. Also noticed from a recent post that the cooling fins are gone on the later models. I'm not really interested in 4.08 swop as I don't feel like the results are worth the trouble.
Sooo... for all those who have swopped theirs...
Should I just stick with 90-93?Is it possible to pull without removing exhaust? (looks like It might come out with some manuevering... Part of my exhaust is welded in so only way to remove is to cut it out.)If I cut the exhaust, I'm going to just go with straight pipes
..Drew..
I had the same problem with my 95 Q Touring. I was in Atlanta at the time and got one from a yard that said it had only 85k miles. I was overjoyed to find one with such low miles. Well, I went thru an ordeal to change it out in my Mom's garage. I had to head back up to NY for classes and got everything done the night before I had to leave.
It should have been time of satisfaction. Instead, problems. The first thing was the TCS light was on. I couldn't figure out why. I double checked all my connections. Everything was good. Finally, I looked at the reluctor gear on the two diffs and I noticed the problem. The one from the JY was from an older Q and the reluctor gear teeth count was different than the one from my 95 Q. So that was bad.
What was even worse was the whining coming from the so-called "low mileage" diff. It was just as bad as the one that came out. I was pissed but I couldn't do anything since I had to leave the next days for my long journey.
So what am I trying to say? If you can get a true "low mileage" unit, go for it. Make sure the ABS reluctor ring pattern matches your current unit.
If you can find a place to rebuild your diff and replace all the bearings and chech the lash, that's the best solution. I recommend UNITRAX since they have done a lot of work on R200 diffs.
