ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Thu Jul 14, 2011 5:51 am
At 1/2 left it is more than time to clean up. These brakes will last a very long time if you care for them. EG is the mileage above and 250,000km on mine.
To start with the fiber friction material must be cleaned from glaze, a sanding with sand paper will do nicely, just be clean, even pressure and also knock off barbs and material at leading and trailing edges of the shoes.
Clean up the drums, sand paper is OK, then clean out with brake cleaner then measure the drum diameter with an accurate depth gauge and see that they are still within spec. Inspect the drum inside and outside, remove rust build up.
You need to lubricate the shoes at 3 points, the manual will show where, but you do not need to take apart.
After sanding the surfaces, use a flat blade large screwdriver to lift the shoes separately at the point of lubrication and with another smaller flat screwdriver and high temperature anti-seize, place a dab at the location specifies then drop the shoe back into place, do all 6 spots, then lubricate the E brake spring and cable at the wheel assembly entrance.
After cleaning and lubricating, now spray brake cleaner on a clean rag and wipe the brake shoes friction surface and the 6 areas clean and clear of any lube, the lube should only be between the shoe metal and metal backing plate.
Clean all brake dust off (wear a dust mask) clean the brake cylinders, inspect the cylinders for leaks, inspect the axle seals for leaks.
With no leaks any where of oil, hypoid oil, brake fluid and all is clean, use a hammer handle to slightly bang on the shoes to confirm movement then put the shoes in square with the wheel so that the dram can be put back.
Keep hands away from friction surfaces, place drum over shoes. If drum has a worn down section where shoes run you may have to use a lathe to clean up the brake surface. With the drum over the shoes turn and push until it seats. It should go on easily but if it is too difficult remove the adjuster plug rubber on the back side of the brake wheel assemble and use either a large flat bladed short screwdriver or adjusting tool to retract the star wheel adjuster to make smaller the shoes diameter and when the drum goes on verify it is all the way on, then readjust the star wheel with both rear wheels raised and feel how tight the drum turns by hand.
A raised rear end with Limited Slip differential will turn both wheels the same direction but will take more effort. Use a wooden stick and the studs as leverage to turn the drum while testing as you adjust the rear brakes. They need to be adjusted fairly snug but not tight you must be able to turn the drum by hand with little effort. Too tight will cause the rear brakes to drag, lock up the diff, eat too much gas. Be very cautious because both sides are working and turning, but you will have free play on each side to feel if the shoes are too tight or too loose.
When done and lowered the e brake should tighten up and hold the car in D or R at about 5 notches. Check the cables and lubrication points for the e brake there is also a nut and bolt adjustment under the handle.
This service is done every 3-6 months and when done regularly becomes easier and not much adjusting but if not done often will be a longer job and you must check your brake fluid reservoir before and after the job, do not fill until after the adjustments.
Brake bleeding should be done on a regular basis and if not be careful not to bust the bleeders from rusting.
