Rear Drive Axel oil seal
zypor
Have leakage on the RWD Axel oil seal. FSM calls out special tool KV40104100. It appears this bolts to the FLANGE ASSY-SIDE to remove it from the differential. Has anyone done this without the special tool? And if you have any another suggestions when you have performed this. 2004 G35 2WD Basic
