VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Fri Jan 03, 2025 2:32 pm
The pinch sensors are a pair of strips located on the edge of the hatch on either side. They're basically odd-shaped grounding switches, they're each connected to a pullup resistor inside the hatch controller and overpower the pullup to ground when something pinches them. I doubt that's the problem unless maybe one of them is shorted. The controller can't detect that, it can only detect an open circuit to cause a code. Since you had codes the last time, it seems dubious that the pinches are causing your issue.
There's a microswitch called the "half latch" inside the latch assembly which frankly causes about 90% of the problems we see with Nissan latches. It detects when the latch cam contacts the striker but isn't fully closed yet. Then the controller runs the cinch motor until a separate "closed" switch tells it the cam is fully rolled over and the hatch is shut. Without a working half latch, the door becomes paralyzed. So even if it's a wiring problem, I'd expect to find it someplace in the hatch umbilical or right at the latch assembly. However, before you throw anymore parts at it, I'd suggest getting the dealer to scan the ABD and insist on a printed copy of the scan. Since they didn't actually "fix" it the last time, if you make a stink, they may just scan it free to get you out of their hair. No service manager or tech likes a "comeback".
