rear door getting really hard to close ?
versa071979
Car: 07 versa
I have an 01 path le the rear door is getting really hard to close to i need to replace the the stabilizers ?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Try adjusting the door striker - see BT-17.
versa071979
Car: 07 versa
i meant the door its self when you pull it down to close it is really hard like you need to but some muscle into it to close it
versa071979
Car: 07 versa
Do the pumps get stiff when they fail I thought it was the other way around ?
Towncivilian
I'm pretty certain the struts are supposed to encounter more difficulty extending as they start to fail; i.e. softer, not stiffer.
versa071979
Car: 07 versa
Any suggestions on why the door is so stiff?
Alfredo24.pr
Car: 2002 NISMO Turbo Pathfinder LE
try spraying wd-40 on the strut rails or whatever it is called
