evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu May 22, 2008 12:24 pm
the maxima brackerts are 82-84 (the 81 was welded on), basically any rear wheel drive maxima with brackets that aren't welded on, the swap uses S130 rear disks and S13 rear calipers
some also use the 85-88 fwd maxima rear brackets with S130 caliper and 84-85 Z31 N/A rotor but this requires extending the e-brake cable to reach, and enlarging the center botre of the bracket to ft over the hub
there was a guy on ebay that sold brackets annd kits using machined alumnum brackets that bolt on, and if you want to spend more, modern motorsports, and MSA aslo sell similar conversion kits and brackets
