C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sun Jul 25, 2004 5:28 am
This tends to be a chronic problem on many cars, especially once it starts. Before putting the rotor back on, I would take a wire brush to it to remove any larger particles of rust. Perhaps even loosen any surface rust. Then clean it up with a good solvent(brake cleaner works fine). Once dry, you can take some anti-sieze compound and spread a very thin layer all across the face of the hub. Then repeat all this for the inside of the rotor if you are reusing the old rotor. The center of the hub tends to need the most attention as well. The wire brush should be used a little more there than anywhere else. This made it much easier to remove the rotor, the last time I had to.
