StillFastQ wrote:Hi,At the end of my rope, looking for salvation. '91 Q45t, runs great, but there is a LOUD whining that starts as soon as I start rolling in gear and gets louder the faster I go. One Infiniti mechanic said it's the driveline. Another I-mechanic says it's the rear diff. They won't work on it, will only replace it. replacement cost, $2,800. What does the online mechanic say?
A) Is this common in a Q with 150k miles?
Depends on the maintenence history. If the fluid in there came from Japan, I'm not surprised. With even marginal fluid changes, you should get around 200K.
B) Could it be something else?
Possibly the driveshaft... typically you'll find play in the center carrier, but that usually shows up as a balance issue. Maybe a rear wheel bearing? A good tech with a mechanic's stethescope is the best way to pinpoint this type of thing.
C) If not, is there a fix other than complete replacement?
Cheaper and easier to replace with a used unit - preferably low mileage from a 1996.
D) If no to C, can someone point me to a good pick-a-part in Southern California?
Check out
www.carpart.com
E) If yes to C, can someone recommend a reliable independent mechanic in Orange County, CA?
Jerry Tucker has a lot of Q experience. I'd have him give you a third opinion on the problem too. It may be a bit out of the way, but it would be really worth your time to go! Many members have had very good experiences with him. If you haven't gotten your chain guides replaced, he can do that too. This guy has a very good reputation.
Welcome to NICO!
Heath
