Rear differential question/problem??
Spinn3r
Car: 1996 Nissan S14 Zenki T3/T4
While crusing, and letting off the gas its making "bang" noise in rear, If im driving and going thru the gears its fine, only when letting of the gas, when i bought the car the guy said its normal, he was saying LSD was installed and bushings is that normal? since im done with engine work and needs a bit of a tune, im moving to final step " suspenion "
Maybe my bushings are out? i will inspect rear today since im installing new clutch....
MarkRipoll
Car: 1995 240sx
i had the same problem and i put in subframe collars and it made all the difference, or you could put solid aluminum subframe bushings in too.
