as per the 2009 warranty:
https://owners.nissanusa.com/content/te ... _N_WIB.pdf
POWERTRAIN COVERAGE
• The Powertrain coverage period is 60 months or
60,000
miles, whichever comes fi rst.
• This warranty covers any repairs needed to correct defects
in materials or workmanship.
• Powertrain coverage applies to components listed below,
supplied by Nissan except for those items listed under the
caption “WHAT IS NOT COVERED”.
ENGINE
Cylinder heads and block and all internal parts, rocker
covers and oil pan, valve train and front cover, timing chain
and tensioner, oil pump, water pump and fuel pump, fuel
injectors, intake and exhaust manifolds and supercharger,
fl ywheel, seals, and gaskets.
TRANSMISSION AND TRANSAXLE
Case and all internal parts, torque converter and converter
housing, automatic transmission control module, transfecase and all internal parts, seals and gaskets, clutch cover
and housing, and electronic transmission controls.
DRIVETRAIN
Drive shafts, final drive housing and all internal parts,
propeller shafts, universal joints, bearings, seals and
gaskets.
you are out of the warranty. the extended warranty that nissan gave to people for 120,000miles/10yrs is for the CVT only.
http://www.nissanassist.com/web/CVT/index.php?menu=8
Nissan has extended the Nissan New Vehicle Limited Warranty for the Continuously Variable Transmission (CVT) to 10 years/120,000 miles (whichever occurs first) for CVT transmission repairs, replacement, and related towing on all 2003-2010 model year Nissan vehicles equipped with the CVT. The remainder of the powertrain warranty coverage for components other than the CVT transmission remains unchanged. All other warranty terms, limitations and conditions otherwise apply."
