REAR DIFFERENTIAL NOISE
deeds8504
Car: xterra
I have a 2003 xterra and i have a whine/howling noise at 55 mph. the nissan techs thought it was a diff, or wheel bearing replaced both and still makes noise. the noise comes with the throttle when you tap the throttle at 55 it gets louder and when you let off it gets quieter. if you have any solutions or comments please let me know.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Could be a few different things including carrier bearings or the pinion bearing. Could also be worn or improperly backlashed ring and pinion gears. Have you checked your diff oil for shavings, etc?
deeds8504
Car: xterra
I didn't find any more shavings than normal. do you think that the backlash could be wrong on two differentials, when i replaced the diff the noise was exactly the same. is there a special type of fluid i can try to quiet the noise?
Desert Rat
2017 Frontier 4.0
2008 Boulevard C90T
No, that's not likely. Since I don't know what's in there, I'd recommend a good 80w90 synthetic gear lube. Will cost you about $20 to drain and refil if you do it yourself. It takes just under 3 quarts. Be sure to loosen the fill plug first to ensure you can get it broke loose before you drain the diff.
