Turned the input shaft and its right at 4 turns to 1 rotation, not less than 4 at all and not quite 4.5 so Im guessing it should be 4.11 gearing??the converted wrote:Turn the input shaft and count how many times it takes to get the outputs to turn once. Should be 4.11 or 4.36ish.
