Rear differential fill plug size?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Does anyone know of a socket I can use to remove the rear differential fill plug? Its appears to be a pipe plug fastener and larger than a 1/2 inch, At least the fill plug is. The drain seems to be a 1/2 inch. The fill plug is not rounded but a two foot breaker bar wielded by a 300+ pound guy on a lift could not break it loose.
I do not feel comfortable with torch near so much oil under pressure (Active Q45).
I soaked it with whatever I could find in the shop and no luck! The drain plug is loose, Didn't drain diff yet. This is for a 1994 Q45 non vented diff cover.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
It appears you can get one of these..
http://ultimatetoolco.com/13mm
13mm square would be what you need..
