as long as the axle code matches, not the number but the 1st 2 letters, i.e. HG, HF, CA if yours matches its the same axle. if the numbers are different i.e. 41, 43, 46 the gears are different. it is ideal to grab the same code so you won't have to change the front axle to match. look at the sticky that Desert Rat posted, this will tell you what axle you have, i.e. CA200, H190 or H233B.
H233B is the strongest, you should have a R200 front axle, but I would verify it first with the sticky ( its like the 5 post on this forum...
all-you-needed-to-know-about-nissan-axl ... 33955.html ) if you have the R180 front axle I would grab that from the pathy as well.
