rear diff bushings
nd_aussie
Car: 1994 300zx 2+2 bout to be tt&1987 rx7 s5 turbo II
ok so ive come to the conclusion that my rear diff bushings must be bad so i was wondering how hard are these to change and does anyone have a write up. also i want to run with energy suspension bushing(good or bad?idea?)
es.biggs
Car: 1990 300ZX 5sp NA
They are pretty difficult man. That's the hardest thing I've done to my car besides the motor. It took me probably 4 hours...maybe 5 or 6 I can't remember it felt like forever though lol. That was with a lift and air tools and a transmission jack to hold the diff. So it was as easy as possible and it still took that long. I used the ES bushings, they are great man. 4 or 5 thousand miles later and I still love the clunk-less shifting :)
If you have the time, tools and will-power to do it then I highly recommend it. It really changed the feel of the car a lot, much tighter and no more clunk in the back. Difference is like night and day. The clunk was so irritating, this is probably the most satisfying repair/mod I've done to the car!
Look what I found lol: post5902154.html
This is hands down the best write up for the job:
http://docs.google.com/viewer?a=v&q=cac ... Q1cg&pli=1
nd_aussie
yea well im worried because i feel that the bushings are bad but something feels wierd in the back end. when i gas it making a right handed turn from a complete stop i feel like i have no power. also i hear clunks when making a hard turn so im worried
es.biggs
Clunks during a turn doesn't really sound like diff bushings.
My bad diff bushings would clunk really bad every time I would lightly press the throttle on and off. Also every time I shifted. Basically loading then unloading the drivetrain would make it clunk.
nd_aussie
so what do u think?
es.biggs
You have no play in the wheels? Did you ever figure out your problem from another thread that could be a bearing?
Lack of power and clunks are two separate problems probably.
Get underneath and look at all the bushings...control arms, sway bars, ball joints, subframe, and see if any look bad.
CrazedZ32Owner
Car: 91 Z32 TT(no motor), 2008 350Z Nismo, 05 Pontiac Sunfire speed machine!!! :)
i also found it quite odd that my TT does that as well and i have a 1 peice D.S.(so no U-joint that can fail) Now i have an idea where to look TY biggs
nd_aussie
it literally sounds like metal grinding on metal like a bearing poped but when i jack the car up and try and move the wheel i have no play what so ever in the wheel. i do however have play in the axle coming out of the diff on the drivers side. i only have lack of power when im completely stopped and i start my turn and about halfway thro the turn i gas is and it just laggs big time. this has never happened before
es.biggs
I wish I could come see it man to try and help but I have no idea. That's a pretty nutty problem...might have to take it to a shop
nd_aussie
yea i know and that erritates me with a passion becasue im not about to spend alot of money and find out its something dumb. so i guess ill just keep diggin. wish i had a place to start and look? no other suggestions?
JaredM
Car: 1990 z32-300zx
clunk might be a balljoint in one of the control arms in the rear or tie rod end up front. Or so was the case for myself.
nd_aussie
i jacked it up and shook the wheel, found out the clunk is coming from the lower control arm bushing the one on the lower portion of the control arm closest to the lsd. but i still would like to know what the ef the lose of power around a turn is from, only from a start to the middle of the turn while trying to gas it
