Da Dark Jedi wrote:Use Amsoil Severe Gear oil in 75W-90, 75W-110 or 75W-140. Performs better than Mobil.
Okay, but more out of curiosity than anything else: do you have any test results or site link that documents this difference in performance?
The reason I ask is that, in most cases, differential gear oil is not as big a deal as engine oil (that see far more heat, etc.). So, once you pick a good synthetic gear oil and it has LSD additives, anything more is probably much overkill - again, if you have test results to the contrary, I'd love to read them!
Since Mobil 1 Synthetic gear oil is more generally available at typical auto parts stores than Amsoil, I'd use it without hesitation if that was all that the store (that I went to) had in stock. Of course, if you still want to use Amsoil, and find it easily enough, then that is fine too.
Z
