rear defroster
2005maxima1
Car: 2005 maxima 3.5SL
2005 maxima 3.5L SL rear defroster will not work. light at switch does not come on. checked fuses at dash and under hood all good. whats next?
Sawyer_
Car: 5th Gen Maxima 2000
Check connectors near LH and RH rear pillars, LH is +12V, RH is ground.
When you press the switch, do you hear the relay clicking?
Also do the door mirror defoggers work when you press the switch?
Might want to also check the condenser which is in the LH rear pillar which connects to the rear window defogger through the rear window defogger relay.
