rear defogger wont work
popogto
like the topic says. its a 89 240 w/ 95 ka.the light on the button lights up. but no work. btw where is the fuse for that thing? in the engine bay?im a n00b, any help is appreciated.thanks.
eddiec
Car: 91 S13
use a test light to make sure you are getting voltage to the connector in the rear. i dont have an fsm handy but the fuse may be under the dash. since the light comes on the switch is probably still good.
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
Is probably a broken wire or connector.......if you are getting a light on the switch is not the fuse, mine had a broken wire and to make even harder the defective section of wire was inside the hatch...I had to maneuver my way around that one....do a continuity check (multimeter) .......
phuphyter
Car: 2002 Infinity G20
i have the same problem. i have a multimeter, but how do i use it? i'm totally clueless.
