Rear defog, taillight strip, and vents...
Imperialis
Car: 1990 240SX SE Fastback
This is for a 1990 240SX. My AC motor recently blew itself out. Since then my rear window defog doesn't work, that strip of breaklights on the top of the trunk won't light, and the vents in my car won't change direction anymore (i.e. blow on the feet, face, both, winshield defog, etc...). I've looked at the fuses and they seem ok, but I'm going to double check them again. Is there any other suggestions on what could be the problem or maybe which specific fuses to look at? I checked the FAQs so any other information would be appreciated. Thanks.
ETTInnov04
Car: 1989 Nissan 240sx fastback
Check ALL the fuses under the hood and ALL the ones in the drivers footwell. Some things are linked together, so just cover all bases. After that take a look at your third brake light, make sure the bulbs didnt blow...stuff happens sometimes that we can't necessarily explain. Let us know what you find.
