Rear Camera Install - 2018 Versa
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
xxxNissan350xxx
Car: 2018 nissan versa
Hi, can't figure out the hot wire for the back-up light on this car. There is a pigtail connector that plugs into the rear assembly. Wires are from the left to right, red, blue, green, black, and yellow. A green pin /button is on the extreme right side of the plug. Which wire is the hot one for the back-up light? Cannot google it anywhere. Thx
PapaSmurf2k3
Site Admin
I'd just unplug the harness and put a multi-meter on it and have someone shift into and out of reverse while you're back there (with the brakes on!!) so you can check to see which wire goes hot when reverse is on.
xxxNissan350xxx
Thx, i'll try that. Harness plug is really tough to disconnect.
Return to “Versa Technical Discussions”
