Rear camber plates, universal?
Neejay
Are rear camber plates universal? The ones Im thinking about getting came off a set of buddy club coilovers, so would they fit on some Tein Basics? I think they only come with the plates and no bolts or anything.
Exar-Kun
Car: 2005 350Z
uh you cant adjust our rear camber with plates...you have to use the RUCA(you know...because it was made for adjusting camber..)
are you thinking about the FRONT camber plates?
-chet
Neejay
Exar-Kun wrote:uh you cant adjust our rear camber with plates...you have to use the RUCA(you know...because it was made for adjusting camber..)
-chet
Nope, I honestly dont know anything about the rear camber adjustment. I thought it was just a matter of adjusting the camber using the camber plate (somehow). So they are actually just pillowball mounts that are NON-adjustable?
skillzilla
ya, those are just rear pillowball mounts. I wish the rears could run camber plates :)
Neejay
-chet
So the OEM ruca can be adjusted for camber?
BuudWeizErr
Neejay wrote:So the OEM ruca can be adjusted for camber?
yes, via an eccentric bolt. when you start lowering it far, you will run out of adjustment and thats when you need an ARUCA.
Exar-Kun
Car: 2005 350Z
ChunkiDori wrote:yes, via an eccentric bolt. when you start lowering it far, you will run out of adjustment and thats when you need an ARUCA.
yep.-chet
Neejay
Are they OEM, or aftermarket? And there arent any long term effects (as in suspension compnents failing because of just using a bolt?
I'll be installing some Tein basics, and doing daily driving.
PGBrian
the eccentric bolts come on the car from nissan.i dont remember how much room they have for adjustment.maybe 1 degree at max.using the bolt will work fine if you dont have a lot of adjusting to do.i use adjustable RUCAs. easy as pie, and twice as tasty!
