BuudWeizErr »
https://forums.nicoclub.com/buudweizerr-u1639.html
Mon Oct 04, 2004 7:37 am
My ebrake decided it didn't want to lock up the rear tires anymore. It didn't do this overnight, I just don't think I noticed because I was clutch kicking so much, but now that I'm trying to combine the two, pulling the ebrake does pretty much nothing other than slow me down very slowly. It locks enough to keep the rears from moving when it's parked, but not when I'm driving.
One of my friends said to get new rear calipers... my car has 225k on it, and they are probably OEM. So I did, same ****, just piston seems to engage smoother now. I'm sure I needed new rears, but I was assuming this would fix my locking problems. I have Axis pads, xdrilled/slotted brembos on the rear. And I've tightened that bolt on the actual ebrake assembly, none of this does any good.
Now granted, I went from S14 SE's with 205/55/16's to 17x9 with 215/45/17's, but one of my friends has the same size wheels and tires with stock brakes and autozone pads and he initiates with ebrake no problem.
Any ideas? And no, I don't want Z32 rear assembly. It's not a problem of me not feinting hard enough or not pulling hard enough. I can feint hard as hell and the ebrake won't do anything. I've also tried putting a spacer on my ebrake cable in case it was stretched... same thing.
any ideas? Chet? Alan? Bueller?
