im having huge problem when trying to replace my rear brake rotors.
both the 19mm caliper bracket bolt stuck as hell. (the other 14 mm were quite easy to remove cuz i did pad change every year... rotors? never in these 5 years/70k miles until today)
i havent touched the front rotors yet, but i would assume they will have the same problem.
after watching some online videos on caliper bracket bolt stuck problem, i saw people were using breaker bar and impact wrench as the solution.
i think im gonna go for the breaker bar, and i do believe breaker bar will take care of the front bolt.
but after i had a look of the rear caliper, i saw the rear strut was taking the space of the bottom bracket bolt. so im not sure will i have enough space to put the socket and a 12 in breaker bar? (im sure this space is no enough for impact wrench tho)
or do u have any other suggestions on this stuck bolt?
Thank you very much for your time, have a good day fellas.
PS. i have tried the hammer on wrench way on the stuck bolt, just no luck.
