Rear Bushings Leaking??
IrvW
Car: 2001 I30
2001 I30. I have a leak on both sides, right in front of the rear tires. The driver's side is leaking more. It is not brake fluid, gas, or water. It feels like some oil based substance.
Are the rear bushings liquid filled?? What can it be??
Thanks for your assistance!!
Q451990
My guess would be that your rear shock absorbers are leaking oil... not sure about the bushings though. How many miles on your I?
Heath
IrvW
Car: 2001 I30
The car has 69000 miles. The struts are fairly new. I will take a look at them when the snow stops.
itarin
Car: 03 350z
The rear bushing is probably leaking lithium grease...this would look like black streaks running down the rear differential cover.
qship96
Car: 1996 Infiniti Q45
except,the i30 is front wheel drive,so there is no rear differential!
RobertsnewQ
Silicone-filled subframe bushings.
