CanuckQx4 »
https://forums.nicoclub.com/canuckqx4-u160090.html
Thu Nov 21, 2013 2:25 pm
First of all, youre making a great choice going with the polyurethane bushings.
1. I see no reason not to get the split design, I have installed them on 2 vehicles, and there really is no need to complicate the job involving a press with the other style, the split design are plenty firm and eliminate the sway completely.
2.You take the metal sleeve out. The easiest way Ive found (without a press) is to simply put the link on a piece of wood or vice held firmly, take a 1-4"-3/8" drill bit and drill around the inner metal sleeve, drilling the holes as close as you can manage to each other, effectively drilling a "swiss cheese" looking circle, at that point you can push the middle out with your finger if your holes are closely drilled, might take a wack or two with a hammer if you left thick portions of rubber.
Then to get the outer metal sleeve out I put a metal blade in my jigsaw, place the blade of the jigaw inside the hole cutting outwards, but flat across the entire inner sleeve, cutting a blade thin slit across. If your careful and cut slow and straight, you can stop just before the blade cuts completely through the sleeve, its not a big deal if you cut slightly into the outer material. Once you get that cut through, you can use a flat head or a chisel to bang the inner sleeve out easily, a can of wd-40 helps to keep your blade cool while cutting, and probably aids in the sleeve popping out easier. The new poly bushings just pop in with a smack from your hand.
3. I to also got lucky and my underbody bolts are still easily removed. I have re-used the bolts on both installations I have done, the fsm does say to replace them, but it adds considerable cost to the job, there big bolts and mine were in good shape so I coated in anti-seize and re-used.
