kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Fri May 21, 2010 7:37 am
Just a note on the clear film installation - it is much easier than your example of a screen protector because you spray the surface of the bumper with soapy water first, slap the film on reasonably well, then because you have a layer of soapy water between the film and the paint you can spend lots of time "sliding" it around and getting it perfectly positioned. Once it's precisely where you need it, then you squeegy out the water/soap solution starting from the center and working outward. It is definately posible to get annoying bubbles, I agree, but the project is doable on a relatively flat surface like the vertical face of your bumper, and worst case scenario it gets messed up, you can always peel it off and be on your way.
But, If you are looking for protection from large objects like bikes etc. then maybe the clear film isn't the best choice, it's meant to prevent scratches and rock chips, it will get really chewed up ina hurry if bikes are contacting it, unlike the thick hard black plastic bumper protetor that you installed - this is heavy duty and meant to take lots of abuse and and still stay in tact. Honestly if it was me I'd probably do something like Nice 568 and his blanket idea when loading bikes, and maybe give the clear film a try to cut down on the little surface scratches and nicks.
