Infinitiguy19 »
https://forums.nicoclub.com/infinitiguy19-u84424.html
Wed Sep 26, 2012 8:19 am
I want to remove the rear bumper cover so I can patch some rust in the quarter panel. The rear bumper has eight little 10MM bolts that when you attempt to remove them the head just breaks off. I sprayed PB blaster in there for a couple of days now but that has not made matters any better. I think the reason the hear breaks off is because its a steel bolt that goes into a brass nutsert. So corrosion has built up.
Is there anyway to remove these little brass nutserts? I tried using a punch and three pound hammer but that just makes rust fall from the rest of the car.
Any advice one removing the rear bumper cover is appreciated.
