rear breaks question
jp
Car: 1990 nissan 240sx
ok here's the deal are the rear rotors on an s13 pressed on. I'm trying to put on my 300zx rear break and I get the damn things off. Ive tryed to pound them off and pull them off any help would be usefull
navysnail
nope, they can rust on though.
Project S13
Car: Nissan 240SX Fastback
If you aren't reusing them try to hammer them off....nicely of course (ie rubber mallet/hammer) but yeah if they rust on it takes some persuasion to remove them.
slc240sxse
Car: 96' 240sx SE
Yes, as Project S13 says, you will probably need to beat the holy living crap out of them. I had to lubricate, beat, heat up, repeat, repeat, repeat, and beat beat beat with a hammer. I of course replaced the rotors, and I didnt use a rubber mallet, i used a sledge hammer, and well.. it worked!
DAEDALUS
Car: 1990 Infiniti Q45
You guys don't have the threaded holes in the rotors to push them off with a couple screws?
Sockington
DAEDALUS wrote:You guys don't have the threaded holes in the rotors to push them off with a couple screws?
What do you take us for? Mechanics?
I get people like that in work all the time (Part-time 'PartsPro' at a local PartSource). You just gotta give em' a good whacking and the rust will break free. As previously mentioned, heat may need to be added to help clear up the rust.
I just go around hitting around the lip so it will apply the most pressure per whack.If I'm really pissed, I also grab the BFH (Big F*cking Hammer) and have at it.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
This is the only way your going to get them off,Or use a puller.
