Rear Break job
Sean Paul
Car: 1997 Infinity J30
I recently took my newly purchaced '97 j30 to my mechanic and he informed me that I will need to replace the rear disk breaks soon. I have done break jobs on other cars before, such as a '99 camry and '97 cavelier, and a dodge caravan. But I've never messed with a car like this before. Is there anything I should be aware of? Should I just leave it to the pro's?
Fenvy
Car: 2005 350Z Base 6MT
why do you need to replace rear disc brakes?
the rotor?the caliper?or just the brake pad? yep probably just a brake pad
don't be shy, it's easy as hell, just remov the rear wheels and you'll be able to figure out what to do once you look at it
Sean Paul
i'm not quite sure what the reason is yet. I'm gonna ask the mechanic when I go to pick up the car from his shop tomorrow (he's doing some other work).
If it generally resembles other disk break mechanisms, I'll take a whack at it!
Thanx for the help!
Fenvy
I hvae worked on... 3 disc brake and 1 drum... they are not hard at all
DominickJ30
Car: 1993 Infiniti J30t
The brake job will be just as easy as any brake job you have done.
