Rear Breaings???
chris_clark1979
Car: 2000 pathfinder
I'm preparing to replace the outer seal on my rear wheel bearings and I've looking on the S.M. and it looks like the bearings are sealed off from the gear oil.
Does anybody know for sure? I have bearing grease all over my rear passenger Assembly. At least it look's and smell's like bearing grease but it could be gear oil too that's why i was looking at the S.M. to see if the gear oil lube's them or if there greased.
chris_clark1979
Ok. Well i just called the stealership and they told me that the rear bearings are sealed from the gear oil and they run off bearing grease. Also that i would have to replace the whole rear axle. Because the seals are not serviceable, But the S.M. tells you how to.. LMAO..LOL..
