qship96 wrote:Just a helpful hint to my fellow Q drivers......I ordered rear brake pads and shim kit from IOS a few days ago and wanted to get the caliper pinboots/bushings as they are rubber and based off my last front brake job, probobly in bad conditon....Nissan does not sell these critical items without purchasing the entire caliper rebuild kit, which I dont need {$50+}
Found online pinboots/bushings kit for our 90-96Q rear calipers made by Carlson..part number 16099 for $9 from bestvalueautoparts.com {they have the front caliper boots/bushings also}
Finally, after checking around, most places want $90-100 to flush the brake fluid, Sears only wants $35......worth the gamble? could they really screw up such a simple job more than anyone else while I watch????
Should I get the brakes flushed before or after I replace the rear pads{I am doing pads myself}
Just read your post.My rear brake pads were like 69cents each i think and last til now.For the fluid bleed it's really easy to do not as hard as you think.Good luck.
I wouldn't go to sears in my opinion.My girlfriend took her car there and she had hubs on the rear wheels right.They broke a lug and just torqued all the screws like nothing then we found out when she lost the hub.
Again good luck.By the way alot of people say it's best to ask for replaced parts just to make sure they did it.
P.S.:
To make a bleeder you can use like a thin plastic rubber straw the type kind of used in fish tanks.Then get a bottle and punch a hole on the cap size of the tube.Be sure the tube fits air tight on the bleeder or else your screwed.Then you can also add a hanger on it to hang somewhere while it bleeds.Kind of hard to explain i'll amke one and post pics maybe.Self brake change i'd trust more.
