DrJuice164 wrote:Ya, your front brakes do 90% of braking so getting the rear to lock would be rather difficult. Being a RWD car, its even more difficult to get the rears to lock as they are attached to the drive line.
Why are you trying to get the rears to lock anyway? (using the floor pedal)
If your trying to use the e-brake to get them to lock, new brakes won't help as the e-brake uses a drum style shoe.
My mistake, you are correct, I forgot that S brakes were different than Z/R, been a while since I delt with stock 240sx brakes. I have the same question for you, why WOULD you want to lock the rear brakes other than for drifting.... If you lock a tire, its effectly not stopping you anymore, ontop of that, you also flatspot tires. This is no good because once you start to flatspot a tire, the tire will continue to lock at the same spot compounding the problem.chargerucd wrote:Hello Sir,
It seems that either you don't know what your'e talking about as far as 240s or your'e just not talking about the right model car. See image.
Why wouldn't YOU want it to lock?
thanks for the efforts anyway.
driver42484 wrote:Does your ebrake lock the rears? if it does, you need to get a better set of rear pads. I learned this from yrs of auto x. If you want it to really perform you need to spend some money. Metal masters are great for the fronts and ceramic pads have worked well for me on the rear. The metal masters are harder to lock up then other pads.
He has hawk pads, they are fine, probably the street one - the reason I was wondering what model/type was if they were the racing ones & he tried to perform these brake tests while the pads were cold, the results would be weird.driver42484 wrote:Does your ebrake lock the rears? if it does, you need to get a better set of rear pads. I learned this from yrs of auto x. If you want it to really perform you need to spend some money. Metal masters are great for the fronts and ceramic pads have worked well for me on the rear. The metal masters are harder to lock up then other pads.
