rear brakes locking up
rms13Mike
Car: 1992 Nissan 240sx Fastback, 2005 Toyota Corrolla S, 1990 Toyota Camry, 1998 Honda Accord LX-V6
for some reason the rear brake locks up after i pull down the handbrake IF i pulled the handbrake up halfway up or higher. Could it be just the cable or maybe my calipers are going bad?
help, please
edwards30
Car: 1995 240sx SE
it could be either i would check to see if you cable is ok first..then check the calipers..are you sayin it is staying locked up as you release the e brake or only when you let it go down
rms13Mike
when i pull it halfway up or more and then i pull the e brake down the brake doesn't disengage and stays that way, so for now i pull it just 3 notches, just enough to not let the car roll
Nurokil
Car: 91 240sx Sr20det
I would think it would be e-brake not caliper. If it was caliper it would happen under normal to hard braking also. E-brake is cable operated so would definatley check the cable, better if you have someone help. If you get 2 people have one watch the cable while the other SLOWLY pulls the handle. Once it reaches the top/or full engaged position slowly let the handle down see if it get hung up. Thats what i would do before pulling calipers, start easy.Good Luck
574-240sx
Car: Nissans, Toyotas, Subaru
Check the rear ebrake cables where they attach to the calipers, should be the bare cables where they go into the rubber/plastic covering. While the ebrake is released and rear calipers are locked up, if the cables move and aren't tight then they aren't freezing up. If that is the case then you need to replace the rear calipers or rebuild them.
rms13Mike
okay, ill try to get to it as soon as i get someone to help me. thanks for you guys' help, hopefully its just some cleaning or lubing. thanks
carkook
Well since the e-brake mechanism other then the cable is inside the caliper, I would rotate the piston back into the caliper. Maybe it got out of adjustment.
romerider153
Car: twin turbo vh41 tube chassis s13, s14 and s13 ka-t daily, someone buy my s14
i have the same problem but its only my right rear caliper that is locking up so let me know what you come up with i would imagin for me it the caliper because its only on one side but you never know
rms13Mike
romerider153 wrote:i have the same problem but its only my right rear caliper that is locking up so let me know what you come up with i would imagin for me it the caliper because its only on one side but you never know
if its e-brake related like mine check the wire first if its getting stuck, if not then just look around your caliper and try pushing the piston back it like carkook said
