onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Mon Jan 31, 2005 9:15 pm
I'm not positive, but doesn't the rear lock up first normally on 240's? I know basically every time my car locked up it was from the rear.
Anyway, 1 way I think would change this situation is to get one of the 300zx master cylinders; don't remember which one, but one of them has a lower "splitting point" or whatnot and starts favoring the front brake more. This will probably make braking less fun since you don't have the 300zx brakes though. I only found this out because I was doing research for my 300zx brake upgrade.
Another possibility may be to get oem pads for the rears, and keep your hawks for the front? Maybe if the pads didn't grab as much in the back, they'll less likely lock up? Also maybe take out the slotted/drilled rotors in the back (just to test w/ oem rotors) to see how the difference is, or the stainless lines. Basically just take the "bite" away from the back.
Or you can get a fwd car, - i'm just playing, but I think that "should" fix the rear locking up. hahaha.
