Rear Brakes - Accessive Heat Build-up
Rally240
Car: 1991 240SX S13 KA24DE Super HICAS LSD 5sp
My rear left brakes really heat up even when driving normal. The pads are hardly worn.Also the outter pad on the right rear always wears faster than the inner one.
The caliper pistons and e-brake don't seem to be sticking. The way I test this out is too see if the car rolls naturally on a slight slope, and it rolls fine.
Does anyone know the reason for these?
Thanks
LayNLow240
Car: 92 240 coupe
could be sticky/frozen sliders. i would say just rebuild your rear calipers and get new rotors and pads.thats about all thats left, i dont think the pads are different thicknesses, but i could be wrong.
Chezedik
Car: 1991 Nissan 240sx
F that, coming from a man who knows. It sucks rebuilding the calipers. If you are really good, then do it. But I am really good, and will still pay for reman'd ones. Besides, if you take it apart and can't get it back together the parts store may not take it as a core.
Slipstream
Car: '94 Sonoma, '90 300zx n/a
I had the same problem. I replaced the calipers, then after two more times I did the lines with them and the problem went away. I'd say just redo the whole rear set-up from scratch.
Chezedik
Def lines too, they are intended to be replaced about once every ten years. If they get an internal failure they can do the same thing as bad calipers too.
