Today I took apart the caliper, and removed the pins and boots, cleaned them, and re-greased them with caliper grease as per recommendation of my buddy Paul. My bf noticed that the caliper's piston was extended a little far still, we cleaned it up as well, and had a hard time putting it back on to the assembly. After hooking everything back up, the rotor moved more freely, but there's still a slight resistance. I took the car out for a 3 mile drive, and this time the wheel was only slightly warm. My question is: what the freakin crap? I have to rebuild already rebuilt calipers? Should I try popping the piston out and cleaning it up as well? And lastly, I have two of the floating stock calipers left from my Z brake upgrade, are they the same size as the rear? I figure it would be just easier that way--if they're compatible.
EDIT: Nevermind, i went and looked at my stock front calipers, much bigger (naturally). Well, any advice for getting this caliper un-stuck?
