rear brake rotor stuck
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
waflet
Car: '04 midnight blue g35 coupe
hideehoi have an '04 g35 coupe. i am changing the rotors & upgrading to ss lines. the fronts are done. both back rotors are stuck on. i can not get them off to save my life (possibly literaly ). i have pulled, pushed & beat on them. they wont budge at all. any suggestions, or is there a magical e-clip hidden somewhere that releases them? tia
l8rcuwaflet
awdjdmtalon
Car: 04 G35 Coupe, Diamond Grafite Metalic, Aero package, 6MT
Is the E brake on? If it is release it. There are parking brake shoes inside the drum part of the rear rotor.
JeromeS13
Car: 2008 Subaru Impreza STI
And if that doesn't work, get a larger hammer.
-Jerome
waflet
hideehothe brake was off. i finaly got them off. penetrating oil & a large hammer did the trick. i'm glad i'm not putting those rotors back on!
l8rcuwaflet
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
You can use a little anti-seize between the hub and the rotor to prevent this from happening in the future.
Some rotors also have a threaded hole where you can insert a bolt and tighten until it pushes the rotor off of the hub.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
+1 to the threaded hole
of course penetrating oil/hammer work well...but can take a while. That little 12mm hole can help out
jbillion
Car: 2004 M45 Premium Package
No mods, just keep it clean.
2008 Altima 3.5 SL CVT
waflet wrote:hideehothe brake was off. i finaly got them off. penetrating oil & a large hammer did the trick. i'm glad i'm not putting those rotors back on!
l8rcuwaflet
I had this happen on my Audi a few years back and a gear puller worked like magic.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
