rear brake problems
jonah
I'm having a problem putting my rear calipers back in place on my 1989 240sx. I've changed my brakes several times, but this time, there is too much pressure in the line i think, because i can't turn in the piston in AT ALL. whats the best way to fix this problem. thanks a lot.
jonah
zion
Car: cars, guns, the usual
Take off the E-Brake!!! lol jk man i had to do it...:D
groundhogday1976
Car: 2015 Altima 2.5 S
Did you take the master cylinder lid off? Also, do you have the piston tool that fits on a 3/8" ratchet?
DSM91
Car: boost, cars
It sounds like you have a seized rear caliper. You can try breaking it loose with vice grips, but chances are you just need a new caliper. $20-$25 at most junk yards.
MrFox
Quote »but this time, there is too much pressure in the line i think[/quote]
Did you open the bleeder screw?
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
When i got my rear brake pads the guy at the store asked me if i ever did them before, because what you have to do is twist the cylinder to the right, kinda like ur screwing it in, instead of just pushing it back.
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
Sometimes you can use a pair of large needle nose pliers to catch the notches on the piston to rotate it. To break it loose, open the bleeder and try using a large c-clamp to nudge it loose. If you use the pad on the clamp's threaded end on the piston it will almost always rotate clockwise as you compress it.
DSM91
Car: boost, cars
Vice grips are a lot easier than pliers. I've actually broken a pair of pliers trying to turn old rusted pistons.
Grant@tirerack
You are correct. The ones I've used are the needle nose vice-grip type, not the small wire cutter types. You will need a very beefy plier.
