Rear Brake Problem?
dieselab
doing brakes on a 93 240sx. did the fronts that was easy. doing the rear and was stuck on the calipers. when i try to compress the rear caliper piston in, it seems to be stuck? am i forget to release something? already release the bleeder valve so that is not the problem. thanksplease help
240addiction
Car: 2-s13 daily grinds and auto drag colt
I had the same it gets to the point where they just keeps spinning right? use a c clamp that should compress it with spinning it you need a pretty big one. do one side at a time though so you do not blow out the other piston on the other side.paul
Nismo_Freak
Car: 89 Nissan 240SX
You can get a special tool that will help you to spin the rear pistons in at your local parts place. It should look like a cube w/ a 3/8" wratchet hole on each side.
You have to TURN the piston in ... not compress it in.
dieselab
thanks..got it to work already.
