SlowRide »
https://forums.nicoclub.com/slowride-u2505.html
Tue Sep 12, 2006 7:59 am
Update.I'm such a newb.
I disconnected the brake hose, and emerg brake and thentook off the caliper. Pulled the piston out, slid off the piston boot.Cleaned it up a bit. But a little break lube on the boot. Put the bootat the base of the piston , leaving room to seat the bottomof the boot to the piston housing. Then turned the back in.
Woo hoo.
But i realized that my bleede valve is seized.
Is there a way I can bleed the brake wihtout using the bleeder valve.
